Toyota 3s-gte
Car setups for whatever type of use.
Toyota 3s-gte
Postby michaelschoeman on Mon Apr 25, 2016 7:21 pm
Hi guys this is my 1st post so don't know if I have done this right or am I in the right section, sorry if I am not😬
I have wanted to buy and build a lotus for a long time now and I think I am nearly ready.
I have been looking at the various options and choices with regards to moters, and my question is this...
Can you use a 3s-gte moter in a lotus??
My end goal is track and drag toy for some weekend fun!
Any advise would be appreciated, thanks guys
michaelschoeman
Re: Toyota 3s-gte
Postby Kango on Mon Aug 08, 2016 12:21 pm
Anything cam be made to fit in a Lotus, especially if you going to build your own chassis, but it comes at a cost,,,money and frustration.
That frustration could be the death of yet another project.
Completed Book Chassis & 1600 Kent
Completed +442 Chassis & 16V Toyo
Completed Birkin live axle & 20v Toyo
Building - Exoskeletal Midmount
Kango
Re: Toyota 3s-gte
Postby Wynand on Thu Aug 11, 2016 8:38 pm
I had built a Seven with Toyota 3SGTE motor. Here is the link (my username is Grumpy)
http://www.lotus7.co.nz/forum/viewtopic ... 0&start=70
However, page to the following page to see what I replaced it with which resulted in the perfect Seven, not to much power, not to little, A motor which you can explore the fantastic handling (if set up correctly) of the car and which you can take to your limits and not the cars.
There is such a thing as to much power in a light weight car - really an un-drivable and dangerous beast especially with a proper blown engine such as the 3SGTE no matter how others will try to convince you otherwise.
Rather go Toyota 20V black top.
Something to ponder about; through the ages is is a proven fact and gospel that the sweet spot of power to fully enjoy a Seven is 100hp (78kw)......
Wynand
Webpage: http://5psi.net
Car: McSorley 442E chassis
2.0l Ford Pinto with ZX9 bike carbs
Lightened flywheel, camjob, 4-2-1 exh
5 Speed Ford type 9 g/box
IRS - 3.7:1 diff ratio
Wynand
Return to Setup
Users browsing this forum: No registered users and 3 guests
