Brake bleed problem
Brake bleed problem
Postby XKV8R on Sun Jul 06, 2014 7:16 pm
Maybe someone has run into this problem before
My Birkin was supplied with rear disc calipers that apparently come off a Golf. The brake bleed setup comprises a reducer which sits in a large screw hole in the caliper, and in turn there is a bleed screw that screws inside that. Anyway Birkin have not supplied the correct reducer, it is a brass reducer with a gas thread (9/16" BSP thread) and the M10x1 bleed screw is forced into the 3/8" BSP thread on the inside. The giveaway is that the bleeder screw is way to short and never seats to seal the caliper so that is wrong as well.
So I wasted a bottle of fluid trying to bleed this arrangement.
Has anyone experienced this? I am guessing the only fix is a set of the proper VW parts.
Pete
XKV8R
Return to Birkin
