Building a class B race car
Re: Building a class B race car
Postby muller on Sun Feb 06, 2011 5:03 pm
Got a lot done, but not much to show in the way of photo's
Engine is now built, just waiting for my new clutch cylinder to arrive and I can finalise the clutch setup and fit the engine and Gearbox, that will be a big step forward as I can then start the wiring.
Wishbones came back from powder coating
I've had a few question about the sphericals, they are retained with a circlip on the bottom
Battery fitted
Diff fitted (Forrester 4.44 LS)
Cladding going back on including the scuttle. Once the switchgear layout is finalised the dash will go in.
Postby rooster on Mon Feb 07, 2011 8:45 pm
I have seen a few of the guys who run cortina front hubs run spacers at the bottom and top of the hub,is that purely to change the roll centre or is it to change the angle of the arm at ride height,or both.Just curious
rooster
Postby muller on Wed Feb 09, 2011 12:07 pm
All of those reasons, but mainly to lower the ride height of the car without changing the wishbone angles or moving chassis mounting points
Postby muller on Wed Feb 09, 2011 12:08 pm
Rear panel has been fabricated by Ricardo
Fuel tank trial fitted
Bonnet and nosecone trial fitted
Tonight night the clutch cylinder will be fitted and hopefully we'll get the engine into the car
Postby andredp on Wed Feb 09, 2011 2:36 pm
Nice! Thumbs up :D
Postby BradW on Wed Feb 09, 2011 4:08 pm
Looking fantastic,
Really like the idea on the fuel tank, not wanting to put a spanner in the works but interested how you are going to deal with the regs ?
4.4.4.
The area above the petrol tank must be completely covered by means of an aluminium cover, secured at its perimeter, to prevent fuel spillage in the event of an accident. The use of any other material shall be subject to the approval of the Committee. Should fuel tanks be positioned within the passenger compartment, they will be isolated from the driver by means of a firewall or be enclosed within a separate metal container which will prevent fuel spillage onto the driver or into the driver’s compartment.
Postby andredp on Wed Feb 09, 2011 9:54 pm
I would say probably half of class B run those tanks now.They are coveredwith a seperate metal cover (firewall) to conform to the regs.
Postby muller on Wed Feb 09, 2011 9:54 pm
BradW wrote:Looking fantastic,
4.4.4.
I've been running a similar setup for almost a year now
The side passenger compartment cover fits over this to complete the firewall
Postby muller on Wed Feb 09, 2011 9:55 pm
The fun part starts now
Engine back in
Rear suspension in
Did not have the right bolts (1/2") for the shocks so could not fit that just yet
Postby muller on Thu Feb 10, 2011 9:13 pm
Machined all the spacers needed tonight and finished off the rear suspension
Started with the front suspension
Should have a rolling chassis by tomorrow night
Postby muller on Sat Feb 12, 2011 3:01 pm
We have a rolling chassis!!! Car going for its exhaust on Monday
Haven't set ride height or anything yet
We're using side vents with removable panels for easy access to the engine, also made by Ricardo
Postby muller on Wed Feb 23, 2011 1:03 pm
Got the car back from exhaust and managed to get a lot of the management wiring done, wiring still needs to be tidied up but want to get the car running before I tape everything up.
Oil cooler fitted, not the ideal spot but don't have time to be fancy. If we have temp issues I'll move it later.
Dashboard 90% done, just need top fit the volt gauge and the data logger/display
Postby muller on Sun Feb 27, 2011 7:21 pm
Its been a busy weekend, half of it spent trying to make the car run on more than 2 cylinders. Tried various thing till the point where I swapped out the management unit and got it going. Put old management back in and changed a few settings and she's running! Thank for all the help Andre!
Exhaust is on
Wiring is 99% done, just needs tidying up
Race seat and seatbelt mountings are done, just waiting for the prop to be fixed. Prop place made it 550mm long instead of the 505mm I specified URGH!!!, if it wasn't for this the car would be driving up an down the driveway tonight.
Dashboard is all wired up, incl data logger. Just need to calibrate all the setting but need the engine running a bit better for that
Side vents colour coded
Postby andredp on Mon Feb 28, 2011 6:53 am
Looks nice, especially like the exhaust design. No problem with the help.
Postby muller on Sun Mar 13, 2011 5:03 pm
Phakisa feedback
At the track car kept on blowing fuses until we traced it to a dodgy starter button that was shorting out internally!
In the 2nd session Lauren came back into the pits with the car covered in oil. Once I got back into the pits I refilled the oil and tried cranking for oil pressure - nothing. Lauren also told me the car sounded very rough and I suspected it ran bearings due to oil loss... that is until someone spotted this
and we found this lying in the engine bay
Still need to strip the motor but the bottom end is definitely throw away. I may be able to salvage the head. Japan Auto Trading will be getting a call from me Monday...
PreviousNext
Return to Birkin
