Consentric bearing on 21R\ w58 gearbox to 1600 Kent
Postby 200sxrb25 on Thu May 25, 2017 12:49 pm
Made this spacer made up.
You cut the sleeve of just in front of the oil seal.
200sxrb25
Re: Consentric bearing on 21R\ w58 gearbox to 1600 Kent
Postby 200sxrb25 on Thu May 25, 2017 12:50 pm
200sxrb25
Postby 200sxrb25 on Thu May 25, 2017 12:52 pm
The concentric is of a Ford Ranger 3.2
200sxrb25
Postby 200sxrb25 on Thu May 25, 2017 12:55 pm
200sxrb25
Postby 200sxrb25 on Thu May 25, 2017 12:58 pm
Got 17mm travel on it
Used a sold rond bar to line it up
200sxrb25
Postby BradW on Thu May 25, 2017 1:06 pm
Good Job, you actually only need about 6-7 mm movement to clear the clutch.
Piece of advice from experience put a pedal stop on the clutch pedal, and set it only when the engine is running etc, so it stops the pedal travelling any further than when the clutch is clear, if it is allowed to push too far it will 'pop' the slave cylinder piston out of the cylinder.
Also be careful bleeding don't pump like you would brakes, again chance of popping the cylinder, best way to bleed is put a long pipe on the bleed nipple and suck any air out, just watch the fluid coming up the pipe it doesn't taste nice :-).
Brad
BradW
Site Admin
Postby 200sxrb25 on Mon Jun 19, 2017 9:10 am
Report back... The consentric work 100%... still to do sum fine tuning but works great.
200sxrb25
Return to Birkin
Users browsing this forum: No registered users and 1 guest
