Dizzy mod for Mr turbo on 20V ST
Postby AndreR on Mon Jun 25, 2012 4:15 pm
Hi guys
Who can help me with what the mod entails on a 20V ST to the distributor to use a Mr Turbo management system. I hear that you need to cut off some teeth, but I can't find the exact details online. Instructions/pictures welcome :D
Thanx
AndreR
Re: Dizzy mod for Mr turbo on 20V ST
Postby alpipes on Mon Jun 25, 2012 10:16 pm
Hi Andre.
If I'm correct there are 24 teeth and they only want 4 teeth remaining and then you need to buy an amplifier because the signal isn't strong enough from the standard sensor. But the easiest way to solve this problem is by going to distributor rebuilding centre in centurion and they can fit a hall sensor from a vw golf with a chopper plate with the correct gaps. I stand to be corrected. Try give them a call his name is mike from distributor rebuilding centre 012 653 4251. That what I had to do for a gotech system.it works like a dream. Hope this helps.
Regards Alex
alpipes
Postby AndreR on Tue Jun 26, 2012 8:40 am
Thanx for the reply Alex. I know that you need the Hall effect mod for the Gotech, but I believe you don't for the Mr Turbo. That's what I heard - could be wrong
AndreR
Users browsing this forum: No registered users and 6 guests
