Toyota 20v coil
Toyota 20v coil
Postby Joose on Sun Nov 27, 2011 9:41 am
Hi,
I need a bit of help figuring this coil out :oops: There are two plugs on the blacktop coil - one round one where the lead from the distributor plugs in, and another smaller one with two spade-contacts:
The top plug is easy because it obviously has to take the lead from the dizzy, as seen here:
Now the tricky part :lol: On the harness that Andre built for me, there are also two wires - one marked coil positive and one marked coil negative:
so my question is: where do these two coil positive and negative wires go? Are they supposed to go onto those spade terminals on the bottom plug and, if so, which is +ve and which is -ve?
thanks in advance!
Re: Toyota 20v coil
Postby muller on Mon Nov 28, 2011 10:10 am
Yes they go to the bottom plug and they can in either way and it will still work
Re: Toyota 20v coil
Postby Joose on Mon Nov 28, 2011 10:27 am
thanks muller! So there is no polarity on the coil then? I can just plug the +ve and -ve in any way? I didnt mention that I am running perfect power management. I dont suppose that makes a difference?
Re: Toyota 20v coil
Postby muller on Mon Nov 28, 2011 1:14 pm
Joose wrote:thanks muller! So there is no polarity on the coil then? I can just plug the +ve and -ve in any way? I didnt mention that I am running perfect power management. I dont suppose that makes a difference?
Apparently the coils works slightly better wired up the correct (i.e. as per manual) vs the other, but wired either way it will still work.
I can never remember wich is supposed to be the + and - plugs so just plug them in have never noticed any difference
Re: Toyota 20v coil
Postby andredp on Mon Nov 28, 2011 3:08 pm
What Muller said, but if you are fanatical about it, positive is on the right hand looking at your pic (in other words on the side with the extra clips bit).
Re: Toyota 20v coil
Postby Joose on Mon Nov 28, 2011 3:24 pm
thanks guys! Will wire it up like Andre says then :)
