Fuel gauge
Fuel gauge
Postby Wynand on Fri Jul 01, 2011 7:23 pm
I tinkered with the gauges today and in particular with the fuel gauge to see if everything works OK with the sender unit I have.
For starters, the gauges I have are VDO's Gold Heritage series (older analogue model) and the fuel gauge have three lugs marked "S - ground - positive".
The sender is from a jet-ski fuel tank and the Ohm range within the numbers as specified by VDO and it has two lugs marked "S - ground"
I connected the positive (12V) to the gauge, the S on sender to S on gauge and connected the two grounds to the sender and gauge. The gauge performed beautiful with exact readings as per movement of the sender float BUT wrong way around - sender shows full, gauge reads empty and vice verso. :?:
I the changes the two wires on the sender to try and reverse the reading but it stayed the same. Then I tried to change the polarity, IOW negative to the gauge and positive as ground and no reading then.
What is wrong and how can I rectify the problem without having to buy a VDO sender unit? I tried to fit the float upside down but the stiff wiring of the sender is to short for that stunt and this is when I swopped the wiring at the sender that should do the same trick but as said, did not change the readings.
Can anyone help?
Re: Fuel gauge
Postby Wynand on Sun Jul 03, 2011 8:36 am
Problem solved via another seven forum....
Re: Fuel gauge
Postby flouwford on Mon Jul 04, 2011 4:58 pm
ok, are you going to tel us how you did it?
Toy: Ford MK2 1600 Sport
Daily drive: Ford Fiesta MK5, Rocam RSI, occasional track day
one day ill build a LOCOST, for the kid or wife to race, and neither of those 2 are planned
flouwford
Re: Fuel gauge
Postby Wynand on Mon Jul 04, 2011 7:25 pm
Simply bend the float wire, so it sticks out the other way that effectively reverses it....
Works like a charm but float wire is a bit short now - had to bend it in such a way it curve around the vertical ally bar holding the sender unit not to get stuck - but will be lengthened (to suit) when the fuel tank is made and the float level set for gauge.
