Vapour Tachometer - installation
Postby matteox on Sun Mar 06, 2011 6:11 pm
Hi guys
I have a Vapour digital dash fitted in my seven , but having problems with setup ..............pls help where is best for speed pick up and RPM pick up .........im not good with electrics
I am running a 2Ov Toyota with dictator
Matt
Locost
Toyota 20v with Dictator
matteox
Re: Vapour Tachometer - installation
Postby ross on Mon Mar 07, 2011 9:10 am
I used the inboard bolt heads on the Lobros joint at the diff for my speedo pick up.
Postby matteox on Mon Mar 07, 2011 10:29 am
thanks for that
where did you put RPM wire ? on the coil ? is it reading right ?
Locost
matteox
Postby ross on Mon Mar 07, 2011 11:27 am
Not sure where my system picks up the rpm, but I think it's from the mnagement system, Andre' would know. But if it's like a standard rev counter then you should be able to use the connection on the dizzy, I think.
Postby andredp on Mon Mar 07, 2011 11:58 am
No the Vapor you'll have to connect to coil negative, but IIRC the manual states there are different ways of connecting??
Postby matteox on Tue Mar 08, 2011 2:48 pm
thanks Andre
Did it read accurately , seems to jump around quite a bit ?
rgds
Matt
Locost
matteox
Postby andredp on Tue Mar 08, 2011 3:14 pm
Some yes, some no :) More yes then no, but if you have troubles try and get the supplier to try another unit on your car.
Users browsing this forum: No registered users and 5 guests
