Trail Tech Digital speedo and tachometre
Postby Reno on Mon Feb 22, 2010 12:57 am
Hi guys
I have installed a all electronic vapour instrament cluster, I am struggling with the setting up of it. Does anyone know setings to get the Revs working? Please this would be a big help, I am running a 20v engine.
Reno
Reno
Re: Trail Tech Digital speedo and tachometre
Postby andredp on Mon Feb 22, 2010 8:31 am
Got one working this weekend incidentally, triggered RPM by the management system. What management system are you using on your 20V?
Postby Reno on Mon Feb 22, 2010 11:28 pm
I'm running a dictator
Reno
Postby andredp on Tue Feb 23, 2010 6:48 am
Ok, well then you may be able to use a spare output on the Dicktator to drive the Vapor. You will need to use a pullup resistor since I suspect the Dicktator will also earth outputs. You will also need to tell the management system to give a RPM based output on the specific output.
Postby Reno on Tue Feb 23, 2010 12:02 pm
Thanks I'll give it a go.... see what happens
Reno
Postby Reno on Sun Mar 07, 2010 1:16 pm
andredp wrote:Ok, well then you may be able to use a spare output on the Dicktator to drive the Vapor. You will need to use a pullup resistor since I suspect the Dicktator will also earth outputs. You will also need to tell the management system to give a RPM based output on the specific output.
Hi Andredp I have searched the whole of East London for a pullup resistor, and 90% of the people don't know what it is, secondly I need to know what ohms and watts is the resistor, and is there anywhere in Joburg that I could order on?
Reno
Reno
Postby andredp on Sun Mar 07, 2010 6:14 pm
Hi Reno
A pull up resistor is just a plain resistor between positive and the signal wire. A 1K ohm resistor (of any wattage) should work 100% :)
Postby muller on Sun Mar 07, 2010 7:12 pm
andredp wrote:Hi Reno
you make it sound so simple :P
Postby andredp on Sun Mar 07, 2010 7:23 pm
It is 8)
Postby muller on Sun Mar 07, 2010 8:23 pm
It is 8)
Then why not just say wire in one those little stripy things between the positive and the signal wires??? Then we'd all know what you mean. :wink:
Postby andredp on Sun Mar 07, 2010 8:59 pm
muller wrote:
andredp wrote:
muller wrote:you make it sound so simple :P
It is 8)
Ah well now I know the correct term I'll use it in future then :lol: One 1K little stripy thingy is needed then :D
Postby Reno on Sun Mar 07, 2010 11:19 pm
Ok I'll try and find a 1K little stripy thingy...LOL, in the mean time I hooked a auto gauge rev counter, and I connected it to the negative part of the distributor and it would only show the idle revs(aroubd 1000rpm) . When you Rev it, it moves really slow and nothing higher than 2500rpm. I have tried connecting it directly to the dicktator, but it gives me the same response. And at the back of the rev counter I set the button to 4 cylinder engine, and still nothing. any Ideas?
Reno
Reno
Postby muller on Mon Mar 08, 2010 7:04 am
Reno wrote:the negative part of the distributor
Distributor? Not sure if its a typo, it should be connected to the - side of your coil
Postby Ben on Mon Mar 08, 2010 10:19 am
Wikipedia has a pretty good explanation for pull-up/pull-down resistors: http://en.wikipedia.org/wiki/Pull-up_resistor.
Quote:
"Such a resistor weakly "pulls" the voltage of the non-voltage-source wire it is connected to towards its voltage source level (high such as 5V in the case of a pull-up resistor, or low such as 0V in the case of the pull-down resistor) when the other components on the line are inactive. This is because when all other terminating connections on the line are inactive, they are high-impedance and act like they are disconnected. Since the other components act as though they are disconnected, the circuit acts as though it is disconnected, and no current will flow on the line, and the voltage of the non-voltage-source wire (common between the other components on the line) will be that of the voltage source (again either high or low) following the rules of Ohm's law."
Although that doesn't tell you that it is a 1K little stripy thingy, which is a clear omission on the part of Wikipedia. I shall be emailing their management.
1/2 Locost SA, Rocam build (in progress)
http://www.purevirtual.co.za/locost
Ben
Postby andredp on Mon Mar 08, 2010 10:38 am
:lol: I love this forum. Ben maybe you should let Wiki know that they need to review their terminology in total. I mean, "logic circuit", sheesh, more like black block thingy working with smoke I would think ;)
