warning lamps for dashboard
Postby ross on Mon Oct 05, 2009 10:10 am
Anybody know where I can buy warning lamps to use on the dashboard, I've been looking around but so far have found nothing suitable.
Re: warning lamps for dashboard
Postby Land Locked on Mon Oct 05, 2009 10:21 am
The early ones can be had from most large auto electrical suppliers and the later LED ones can be had from most electronic component shops. The LED version does need a bit of circuitry.
Early globe type front
Early globe type back
Later LED version
Later LED version with lights
In the dark
Land Locked
Postby muller on Mon Oct 05, 2009 11:02 am
I use superbright LED's for all my warning lights (except charging light where you have to use proper light)
Postby Land Locked on Mon Oct 05, 2009 11:09 am
Anton, there is a bit of circuitry to add and the superbright will work for charge too.
Land Locked
Postby muller on Mon Oct 05, 2009 12:03 pm
Land Locked wrote:Anton, there is a bit of circuitry to add and the superbright will work for charge too.
Please elaborate! Would love to know how you did it.
Postby ross on Mon Oct 05, 2009 12:08 pm
Hi Guys,
Thanks for the input, where do you get the superbright leds, I looked in the RS catalogue but some of the prices ar ridiculous like R500 for a single led lamp. Where can I get the leds at a reasonable price?
Postby muller on Mon Oct 05, 2009 12:47 pm
ross wrote:Hi Guys,
Any electronic store has them, just make sure to ask for some resistors that you have to wire in to use them on 12v (the store will be able give you right one)
You can go to communica (off the N1) or even better Yebo electronics in Midrand. No idea of any places closer to you.
Make sure to ask for superbrights, they cost more, about R10 a pop IIRC (or could be R5, haven't bought them in a while), while you are there pick up some LED holders, makes fitting the LED's in the dash a lot easier. You get 5 basic colours - red, green, yellow, white and blue
Postby ross on Mon Oct 05, 2009 3:07 pm
Thanks Anton, I'll go and have a look at Yebo, I was in Communica this morning buying some heat shrink, I had a wander round but I didn't see any lamps, maybe you have to ask for them.
Postby muller on Mon Oct 05, 2009 4:15 pm
ross wrote:Thanks Anton, I'll go and have a look at Yebo, I was in Communica this morning buying some heat shrink, I had a wander round but I didn't see any lamps, maybe you have to ask for them.
Communica will definitely have
Postby Land Locked on Mon Oct 05, 2009 6:03 pm
Ross, comunica do have. Sadly one has to deal with their super incompetent counter staff to get them.
Anton, I'll have a scratch in a bit and post the diagram.(It's somewhere on the computer)
Land Locked
Postby Land Locked on Tue Oct 06, 2009 4:50 pm
Spent some time pm'ing Anton and this is what we came up with for charge light with an LED:
oops, forgot tis was posted here, new link inserted
Land Locked
Postby ross on Tue Oct 06, 2009 9:17 pm
Ok, I think I understand the diagram, there are two resistors, one in series with the led and one in parallel with both the led and it's series resistor. Then there's a diode, I think, in series with all of that? But what's the oil light got to do with it? Electronics is not my strong point. Btw I asked my son about the leds, he's studying electronics at Tukkies, he says that you can get leds that are 7mm in diameter, that would be nicce.
Postby Land Locked on Tue Oct 06, 2009 9:39 pm
Ross the oil light was on the diagram that Anton found. It is of no real bearing on the charge light, I do however recall that most warning lamps use a constant positive and take an earth or negative signal to turn them on.
LED's are available in a huge variety of shapes and sizes.
http://ledz.com/?p=product
http://www.ledsupply.com/led-catalog.php?gclid=CNaJkq-UqZ0CFcRq4wodgkBHkw
http://za.rs-online.com/web/search/sear ... 4294955656
Hope the above helps.
Land Locked
Postby muller on Wed Oct 07, 2009 7:40 am
Land Locked wrote:Ross the oil light was on the diagram that Anton found. It is of no real bearing on the charge light, I do however recall that most warning lamps use a constant positive and take an earth or negative signal to turn them on.
It was diagram I found while googling so you can ignore the oil light bit. As LL pointed out virtually all warning lights receive a constant + via the ignition and the sensor switches the ground to turn the light on
Postby muller on Sun Oct 11, 2009 2:44 pm
Both my and Lauren's car's now have purdy little blue LED's for charging lights!
Thanks!!!
