Tail light wiring
Tail light wiring
Postby Kango on Sat Aug 01, 2009 8:19 am
Thying my best to add lightness.
Does anybody have a wiring diagram to wire up the tail lights so it works like the american cars. One bulb that does brakes and indicator. So if You brake and have the indicator on, the stop light flashes? :?:
:idea: Bad idea perhaps all the wires will be henier than an extra bulp. :?
Completed Book Chassis & 1600 Kent
Completed +442 Chassis & 16V Toyo
Completed Birkin live axle & 20v Toyo
Building - Exoskeletal Midmount
Kango
Re: Tail light wiring
Postby andredp on Sat Aug 01, 2009 11:59 am
Won't have time this weekend, but remind me during the week and I'll try and see if I can do a diagram. Not a bad idea really, just need to clear it with the local traffic plod :)
Postby ross on Sun Aug 02, 2009 10:58 am
Won't comply with the local traffic regs, do the roadworthy first then change the wiring :lol:
Postby Kango on Mon Aug 03, 2009 8:50 am
Andre' .....I am reminding you.
Kango
Postby muller on Mon Aug 03, 2009 9:04 am
The problem is avoiding both brake light flashing when you use the indicators. Because you use a single brake switch you will reverse feed the other brake light when using the indicators. A way I've gotten around this in the past is use a relay - not very elegant but it works. I'm sure Andre will come up with a much simpler solution!
Postby Kango on Wed Aug 12, 2009 9:15 am
Andre' reminding you, but take it you are more concerned anout the GB.
Kango
