XMS L vs the new XMS 2A
Postby andrewturner on Tue Dec 02, 2008 2:02 pm
Can anyone tell me th difference between the old XMS L ECU from Perfect Power and their new unit XMS2A
andrewturner
Re: XMS L vs the new XMS 2A
Postby andredp on Tue Dec 02, 2008 3:04 pm
Info available of their website: www.perfectpower.com, but practically:
The XMSL has built in AMP sensor, XMS4A-2 doesn't, XMS4A-2A does
XMSL has built in coil drivers, XMS4A needs external coil drivers(often built into the coil these days)
Send me a pm if you want more info, and I'll send you my email addie/cell nr and wer can chat. A bit too much to type out right now.
Postby Joose on Fri Aug 21, 2009 11:53 am
Which one is better for a Blacktop? Also, Which ECU has the best support up here in Gauteng?
Postby andredp on Sun Aug 23, 2009 5:25 pm
Do you have a preferred tuner? I suggest you go with the management system your tuner is comfortable with. The XMSL works on the 20V's with their standard triggers, but I am sure the XMS4's will also work just as well. I have one if you want to try it, let me know.
