Wiring up Perfect Power XMS-L on a 20V
Postby muller on Wed Oct 15, 2008 8:58 pm
A lot of people are using XMS-L and like us have battled to get it working properly on the Toyota dizzy. Here is the idiots guide to wiring up the TPS and dizzy:
I'm using the same references as perfect power for the wiring (9/16 etc refers to the XMS-L wiring i.e. wire # 9 on the 16pin plug)
TPS (pin numbering as moulded on the TPS plug)
Pin 1 – 9/16
Pin 2 – not used
Pin 3 – 13/16
Pin 4 – 16/16
Distributor
(I'm numbering the dizzy wires from top to bottom as it is plugged in, i.e. 1 = top wire)
1 – 3/16
2+3 – 11/16 (i.e both pins 2 and 3 gets connected to 11/16)
4 = 2/16 and 10/16 & ground (to engine on dizzy side and chassis management side)
Though XMS works on the stock Toy dizzy it does not like it very much and it’s prone to interference. On the Locost we had no problems but on the Birkin we had endless problems with interference around 7000rpm. If the RPM signal on the management flickers to 9999 then that means you are picking up interference. We solved this by:
Double grounding the wires – not sure why but this is needed.
Using shielded wire and running it as far away from the dizzy, coil and plug leads as possible
Adding a little metal shield around the dizzy plug
Hope this helps!
Re: Wiring up Perfect Power XMS-L on a 20V
Postby Trev on Wed Oct 15, 2008 10:15 pm
Hi Anton
You refer to interference problems with XMS system... Does the same apply to the xms-l system?
20 v Velocity - Licenced!
Trev
Postby andredp on Thu Oct 16, 2008 7:15 am
Anton is referring to the XMSL here, but you will have the same issues on the XMS, which is basically the same thing. The XMSL is the "little brother" :)
Postby Reno on Sun Sep 20, 2009 7:35 pm
muller wrote:A lot of people are using XMS-L and like us have battled to get it working properly on the Toyota dizzy. Here is the idiots guide to wiring up the TPS and dizzy:
Pin 1 – 9/16
Pin 2 – not used
Pin 3 – 13/16
Pin 4 – 16/16
Distributor
1 – 3/16
Hope this helps!
Hi guys
this is most probably a stupid question to you experienced guys "I'm a newbie to this" WHAT IS A DIZZY?
Thanks Reno
Reno
Postby Van on Mon Sep 21, 2009 8:58 am
Reno wrote:Hi guys
Thanks Reno
My dad and I were just as confused in the beginning so dont feel bad!! It's a distributor :wink:
Ettienne
Building: Haynes Roadster -- 20V Silvertop -- T50
Van
Postby Gerrie on Mon Sep 21, 2009 9:52 am
I guess its so called coz if you were small enough to sit on it and hold on real tight you will definitely get very dizzy! :lol:
There's also the tranny that makes you go fast 8)
Luego Viento
Rover V8
Gerrie
Postby muller on Mon Sep 21, 2009 12:04 pm
Van wrote:
Reno wrote:Hi guys
Thanks Reno
LOL!!!
Just so much easier to type (and spell!) than distributor
Postby BuzzFuzz on Fri Apr 12, 2013 3:09 pm
OK so I have been underground in Stealth Mode for a while, but I've eventually started trying to plan my electrical side of things... I have pretty much everything, now its just starting to connect all the dots.
I have a PP XMS-L and a 20V and a Nice new battery :D
This is what I've come up with so far. Hoping I can get some advice to see if I'm on the right track.
Hope its right
Postby BuzzFuzz on Tue Apr 23, 2013 8:08 am
I'm not sure about pins 3 & 11 & 2 & 10 on the big plug.
I probably read Muller's comments wrong "
Also not sure if the fuel pump relay is done correctly.
Postby BuzzFuzz on Tue Dec 17, 2013 11:21 am
OK so I got her started a while back, and I have a few days leave coming up :D so I can work on her.
Question is with the Perfect Power temperature sensor wiring.
Does one really need the output 16/16 (+5 Ext) to go thru the resistor and what does the resistor serve to do?
(I'm having trouble finding this 2K2 resistor and AC/DC tell me they are an electronics store so don't sell this "WTF" - MIDAS and AUTOZONE also can't help me. :cry: )
Postby wacky wayne on Tue Dec 17, 2013 6:59 pm
have you tired electronics 123 they up youre way and got mail service , should not be a problem to find one ,
wacky wayne
Postby BuzzFuzz on Wed Dec 18, 2013 9:35 am
Cool eventually 8)
Thanks Wayne... they have one on their website - 2.2K resistor... its 5c... wonder if they deliver for free :lol:
