Changes to accommodate Toyota Black Top
Postby nicroets on Fri Aug 08, 2014 12:37 pm
What fitment changes will I have to make the install a Toyota Black Top instead of the Ford Kent X-Flow engine?
nicroets
Re: Changes to accommodate Toyota Black Top
Postby Forwardloop on Sat Aug 09, 2014 10:20 pm
Also curious to know this, as I would like to do it as well some time.
From what I can tell, there would be some plumbing work to do, electrical due to engine management system, fuel system (swirl or capacity tank I think?), and mostly likely engine mounts.
But lets see what the experienced people have to say. Hopefully its not too major.
1) Birkin, Kent powered - complete rebuild underway
Forwardloop
Postby wattywat on Mon Aug 11, 2014 2:35 pm
I was also having a look at doing this once upon a time... Sorry to direct traffic away from this forum but when I was doing my research I found this topic on The Lotus Register Forum:
http://forum.lotusregister.co.za/Defaul ... posts&t=88
Hope this helps a bit, and as the reply to the post states: Don't trust the rand value! 2003 was a long time ago! :)
Bryce
wattywat
Postby nicroets on Tue Aug 12, 2014 10:11 am
Thanks Bryce.
This will help a lot.
Nic.
nicroets
Postby catherine on Thu Feb 28, 2019 8:21 am
Interesting and proficient Video.
There is 3D PCB printer now, a new innovation for PCB. You can get one if need heaps of PCB model.
Electrical Engineering.
catherine
Users browsing this forum: Google [Bot] and 2 guests
