Rear disc brakes question
Postby Vauxhall on Sat Jan 11, 2014 9:07 pm
Hi all
So im forced to do the rear disc conversion
Ive manufactured the rear uprights my self and failed to use my head and now the back plates of the drums don't fit properly
I know the common caliper is a vw golf caliper
What discs do you guys normally use with the vw setup?
Ive read somewhere that the bantam front discs fit nice but to my knowledge that is a vented disc and i dont think it wil fit the caliper
Your help is appreciated
Thanks guys
Vauxhall
Re: Rear disc brakes question
Postby andersonhdj on Sat Jan 11, 2014 10:19 pm
I used Audi A3 rear calipers complete with cables and escort discs , had to take a small amount off my side shafts to allow the disk to slip over, guess you could take a bit off the inside of the disk instead.
The only problem this leaves me with is that i have to use a 15" wheel for the clearance of this particular caliper but it's a sweet setup as the cables can be used unmodified with a bit of ingenuity.
You will of course need slightly longer studs and need to make mounting brackets for the calipers.
Postby Vauxhall on Sun Jan 12, 2014 9:07 pm
Yeah mounting brackets isnt a big issue
As far as caliper goes i think vw audi uses the same calipers and they all are more or less the same minor differences
Thanks ill look for escort discs
Vauxhall
