Cortina Diff
Engines, Gearboxes, axles and anything in between
Cortina Diff
Postby Jakes777 on Wed Oct 09, 2013 9:28 am
I've been looking though the forum for my answer, but can't get anything on using the Cortina Mk 5 diff for a locost build. And will i be able to widen the frame by 100mm if i use this diff?
Jakes777
Re: Cortina Diff
Postby andersonhdj on Mon Oct 14, 2013 7:01 pm
There's no reason why you should'nt be able to use this diff , anything is possible with the application of the mind.
Bearing in mind it also depends on what you intend to do with your car , you need to be selective about ratio's.
Have you looked at this site http://sevenesque.com/plans/ ? There are plans for extended as well as std "Locost" builds.
Having said that, any deviation from std means that sourcing things like a scuttle and nosecone become problematic unless you hook up with someone who has already built a widebody such as the 442 - 4" wider, 4" longer, 2" higher - 4" being 100mm of course.
I think Wynand has done the 442 and might be able to help in the Scuttle and nosecone dept.
Hamish.
andersonhdj
Re: Cortina Diff
Postby Wynand on Wed Oct 16, 2013 7:12 am
See my reply at Body Work section under Alternative Mold release waxes.
viewtopic.php?f=5&t=2444
Wynand
Webpage: http://5psi.net
Car: McSorley 442E chassis
2.0l Ford Pinto with ZX9 bike carbs
Lightened flywheel, camjob, 4-2-1 exh
5 Speed Ford type 9 g/box
IRS - 3.7:1 diff ratio
Wynand
Re: Cortina Diff
Postby Jakes777 on Wed Oct 16, 2013 1:41 pm
Thanx for the link! I will be building the +400, as I'm going to run the 20v motor. The +4 works perfect for the cortina stearing rack as its 4" longer than the escort rack. :D
Jakes777
Return to Running Gear
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
