Removal of Ford type 2 gearlever
Postby Jolly Jim on Fri Aug 30, 2013 6:30 pm
Evening All
My cars' Ford type 2 gearbox is stuck in reverse. This could be due to a broken selector fork situated at the bottom of the gearbox. Question is; how do I remove the gearlever? The gearlever has something like castellated tabs at the base of the gearlaver that seems to be bent over the lip of the gearlever opening into the gearbox. Do I need to bend the tabs open to remove the gearlever? Can this be done with the gearbox in situ, or should the gearbox be removed from the car? Where can I source sparescfor a Ford type 2 gearbox, preferably in the Centurion area?
All advise gladly received.
Lead me not into temptation - I can find it myself.......
Jolly Jim
Re: Removal of Ford type 2 gearlever
Postby andersonhdj on Fri Aug 30, 2013 11:55 pm
Lift the tabs and unscrew the lever assembly , be careful not to loose the little nylon horse shoe between the lever fork and the selector rod , should it come out. Can be done "in situ" , will make removing the box easier.
Postby Jolly Jim on Sat Aug 31, 2013 6:53 am
Thanks Hamish!
Jolly Jim
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
