Ford V6 Weber clean up and set up
Engines, Gearboxes, axles and anything in between
Postby Redshift on Thu Jul 11, 2013 8:06 am
Hi All,
Here is a update on the engine side of things.
I have taken the engine out of the car and took the carbs off for a clean. It was in desperate need for a clean after 8 years of standing.There was more dirt and grime inside the carbs than on the outside of the engine. I really struggled to get some of the jets out, it was stuck in way too tight but after a long paraffin bath (overnight) it come loose.
I have attached some pics of the engine and carbs and will also post the pics of the finished product soon.
P.S. There has been a lot of construction happening this week and will post all of it when I get a chance.
Previous posts:
1. viewtopic.php?f=1&t=2411
2. viewtopic.php?f=5&t=2416
and more to come...
Stephan Grové
“To achieve anything, you must be prepared to dabble on the boundary of disaster.”
Redshift
Re: Ford V6 Weber clean up and set up
Postby Redshift on Thu Jul 11, 2013 8:23 am
some more pics
Redshift
Postby Redshift on Tue Jul 16, 2013 7:29 am
Hi All,
Sorry, I have been a bit busy with other things and haven't had time to post the rest of the pics... but here are some more for now.
Stephan Grové
Old clutch
New clutch
Redshift
Postby Redshift on Tue Jul 16, 2013 7:38 am
And more pics...
This is the water choke port for the Webers (38DGAS), I had to clean all the corrosion off before I can fix it again.
The next will be of the fixed unit...
Stephan Grové
The broken part
Some more corrosion
Cleaned the broken part
Redshift
Postby Redshift on Tue Jul 16, 2013 11:41 am
Here's some more pics after the carbs were cleaned up...
First some pics of the jets and then some of the carbs.
Before
AFTER !!!
Redshift
Postby Redshift on Tue Jul 16, 2013 11:42 am
Here are the carbs...
Redshift
Return to Running Gear
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
